GT3 Swaybar install on C4s (front)
#46
#47
#48
The H&R c4 front is 25mm, rear is 24mm. But consider that this just the physical size and solid bar. The adjustable holes will allow you to effectively make them stiffer.
Bigger isn't better, tuned is better. There's a reason why the C2 model is slightly bigger at 26mm front. The AWD version doesn't need as big bars as the RWD.
