99 996 HELP1
99 996 HELP1
Hi All,
Looking for a little advice/help. My 99 996 with 45k is reasy for a new clutch/rms and I would like to do the flat 6 IMS upgrade. Does anyone have a shop recommendation in the Buffalo NY area (rochester works also)?
I am looking for someone that has experience with the IMS upgrade procedure.
Thanks in advance!
-C
Thanks in advance!
-C
The bearing is sold by LN engineering.
You might want to just consider purchasing the IMS Guardian instead from Flat 6 Innovations. When it is released in the next few months it will warn you of IMSB failure.
It is possible the bearing in your car will last the life of it and a replacement is not necessary.
