996 Forum 1999-2005
Check engine light revealed...
Old Jul 7, 2011 | 10:48 AM
  #31
Hardback's Avatar
Hardback
Riad, Im having the same issue but my tech is telling me the check engine light could be caused by bad O2 sensor/s either before or after cat or the cat/s themselves. How did you decifer that you need new cats and not new sensors instead? Did they swap sensors first? Cheaper solution obviously...
Old Jul 7, 2011 | 11:41 AM
  #32
redridge's Avatar
redridge
I would check the codes out first.... but as for Fabspeed vs FVD, the cats are made by the same german shop (HJS) but I would look at the build between the two... one is better than the other.
Old Jul 7, 2011 | 02:39 PM
  #33
Zookie's Avatar
Zookie
i would look at Customer Service
Old Jul 7, 2011 | 08:15 PM
  #34
Riad's Avatar
Riad
Chandler!
I'm going to buy a code reader tomorrow... check the codes myself and take it from there. I will not be replacing the OEM cats... if I have to go down that road I'll just go Fabspeed or AWE and at least have some fun.
