Question - Oil loss -Engine quits?
Referring to the frog 2's post
https://rennlist.com/forums/996-foru...-with-pic.html
Considering all of the electronic monitoring devices in our cars.
Is the DME smart enough and/or programmed to shut off the ignition if it senses a no oil level & pressure situation?
With no oil pressure will the cam chains immediately jump timing?
The mk2 cars will turn the instrument cluster red, display "low oil pressure" message, illuminate the oil pressure warning light and sound a beep. I don't think the DME will interrupt operation otherwise.
