'02-'05 996 Tip Trans Fluid_OEM 000 043 304 01?
Time for a Tip fluid change w/filter.
Is this the OEM fluid and is it recommened to mix?
The 2002-05 Tiptronic transmissions have a total capacity of 9.0 liters. If you are performing a regular service, rather than flushing out all the fluid, you will need 4.5 liters.
000-043-304-01-M853 Fuchs ATF Transmission Fluid Porsche ATF 3353 (1 Liter), Carrera Tiptronic (2002-05), Carrera 4 Tiptronic (2002-05), 911 Turbo (2001-05) (Tiptronic)
Brand: Fuchs
$11.00 (Pelican Parts).
Brand: Fuchs
