Is Mobil 1 synthetic ok?
Parts Specialist
your motor costs $15-20k to fix.... buy the oil that gives you the level of protection you are comfortable with
for me....I used Shell Helix Ultra (very very hard to find, unless you know where to look) $9/qt so a change at home will set you back $110 every 4-5k miles
The Penguin King
Time to jump the noob again guys? Give it a freaking break!
To OP, yes it's perfectly find to run Mobil 1 for street and even moderate DE use.
Mike, calm down. Nobody has jumped the noob. Just some light humor to this point.
And to the OP so Mike doesn't have an aneurysm, not only is it good for "street and even moderate DE use" but also very good for race conditions.
Super Moderator
I have to say I was very impressed with how you guys did NOT jump on the noob.
Aspen, Oil is is obviously hot topic around here.. and in Ivangene's world Hot oil wrestling is a hot topic...
Much missed
I hope Aspen feels like part of the group, too.
I use Mobil 1 5W50 in the Boxster (used Red Line 5W40 very successfully for 3 years too).
I use Mobil 1 20W50 V-Twin in the 993 Turbo.
I do Blackstone Labs used oil analysis at every change (5,000 mile interval or yearly). This is the key to learning how your oil is performing.
