Re : What is Behind the rear wiper motor
Hi
What is behind the rear wiper motor? There is a serious annoying rattle that gets on my nerves!
Anyone knows how to fix it?
Cheers
Cheers
open up the panel that covers the wiper motor. You might have a loose bolt that holds the motor. Also, under the cap of the wiper outside, there is a nut that you can tighten. If the rattle persists, you can put a piece of cushion between the motor and the frame...... Or you can do a wiper delete and use a plug that eric sells at bumperplug,com..... he might even sell the cap painted. GR should be an off the shelf color in stock.
