996 Forum 1999-2005
Window regulator
Old Apr 12, 2011 | 07:07 PM
dr_r2r's Avatar
dr_r2r
Default Window regulator
Any Indy in Chicago who can fix my left side window regulator?
Old Apr 13, 2011 | 10:03 PM
sandersd's Avatar
sandersd
DIY. Takes about an hour if you've never done it and costs $250 including 2nd day air for the part. I just did min last weekend. Dealer wanted $800 - what a joke. Now that I've done it once I could do it in a half hour - it's that easy.
Old Apr 17, 2011 | 06:48 PM
heroin's Avatar
heroin
I replaced mine rather easily. But my airbag light is now on. Any thoughts?
Old Apr 17, 2011 | 07:23 PM
fpb111's Avatar
fpb111
If you turned the ign on while you had the door panel disconnected/off the air bag light will light. If it lit after you buttoned everything up and put the key in the ign then something is not connected.
Either way you will have to go to a dealer to have it turned off or buy a Durametric Diagnostic Tool to be able to DIY. Durametric will give you capability to do many more DIY things..
http://www.durametric.com/default.aspx
Old Apr 17, 2011 | 09:46 PM
sandersd's Avatar
sandersd
I used my Durametric. Must have for any Porsche DIYer...
Old Aug 25, 2012 | 07:13 PM
heroin's Avatar
heroin
Anyone here in AZ that would let me come by to use thier Durametric?
