996 3.4L & 3.6L Cylinder Replacement
Former Vendor
996 3.4L & 3.6L Cylinder replaced with cast iron cylinders. You can reuse stock pistons with our ring pack or we can supply custom pistons.
Cylinder replacement w/stock piston $2800.00 Call for more info 410-668-1100
Former Vendor
There is no problem with exspansion, this is done ever day with Subaru WRX, Porsche 951 2.5L & 3.0L turbo, Honda, Ferrari just to name a few.
Former Vendor
That is excellent to know that there is another option outside of Jake on the East coast if Jake takes 8-9 months to rebuild an engine..
Former Vendor
Former Vendor
Complete engine rebuild to stock specs $10,800 to $12,000 engine must be shipped complete intake to exhaust manifold.
Chains, chain guides, tensioners, rod bearing, main bearings, piston rings, pistons coated, rod bolts, crank cradle bolts, case bolts, cylinders, case machining, valve job & guides, wrist pin clips, polish crank, oil cooler, IMS bearing, check rod clearances, check crank & cradle clearances, rebuild oil pumps, water pump, spark plugs, spark plug connectors, wiring harness inspected, injectors serviced.
How are those test cars running?
Have you had many takers yet?
Any advantages/disadvantages to running cast iron versus lokasil/nikasil?
Assuming one would reuse their existing "in spec" (or new) factory pistons, what is the cost for your ring pack on a 3.4L? 3.6L?
Can you also do bigger bores?
Edit: I think I may have found my answer in the link below regarding iron vs. aluminum and nikasil. Thanks Charles!
https://rennlist.com/forums/996-foru...000-miles.html
