New Car, and Back Problems Already!
Howdy,
New to the 996 board. Pics below of the new-to-me 2003 C4S I picked up recently. I absolutely love this car. Other car is an 88 NA 944; great car, different vehicle.
Here's the question/issue. My back is killing me, literally. Took a 55 mile drive and back yesterday, and I'm remarkably uncomfortable. Actual lower back pain. I blame some of it on German Engineering (seat not meant to cushion, which is fine), and some of it on a very tight clutch that torques my back every time I press it. I've played with the lumbar support and moved the seat in multiple directions, plus brought myself up forward (which I don't like), and nothing helps.
There have got to be some old fogies out there like me, whose backs are bad, and who solved this problem somehow. It might actually keep me from using it as a DD if I can't get less-painful. Could swap out seats, but I'm hoping to avoid that; the car is pretty much spotless and stock as-is.
Thanks and I'm looking forward to learning about this great auto.
Nice looking ride that appears to be nearly a twin for mine from the outside.
Since you mention adjusting the lumbar support does that mean it has the lumbar adjustment (a dual air bladder) that covers a fairly wide range of heights and inflation levels? I have this on my Boxster but not on my C4S so I had to improvise. On the Boxster I can easily get quite a bit of inflation down really low and this helps my back a lot. On the C4S I had to resort to the trick of rolling up a towel and fitting it behind the center seat cushion. It's not ideal but it does solve the problem. At least for me.
Back to the lumbar support. If you do have the adjustable lumbar support option you can verify it operates correctly by removing the center backrest cushion and watching the bladders fill/deflate as you move them up & down and adjust the inflation level. If they are both working then I'm out of ideas other than getting an add-on cushion to augment the level of support.
Ya; compared with the 944 it's like pushing an elephant up a hill. PPI did not mention the clutch worn however I doubt it was taken apart and interrogated. Will have to do a bit of looking.
Thanks for advice on support; yes it has proper support with bladders. Bladder inflates and deflates but unsure it moves; I'll pull the seat back and take a look. Two issues to work on already.
I love this marque! Good thing the 944 prepped me right....
My clutch was very heavy and it turned out to be a broken clutch helper spring.
As far as back pain...I'm old enough and I've had back pain in other cars...although admitadly not all that often. My base stock 996 seats treat me fine and I daily drive 50 miles every day.
Hope you find a position that works, it'd be a shame to not enjoy your car.
Rocky Mountain High
Beautiful car... looks quite a bit like mine too.
Do you have standard seats, or do you have the comfort seat option?
the 996 standard seats are horrible.
you need these - scroll down
http://www.6speedonline.com/forums/9...-new-mods.html
Congrats on the car, looks great. I have serious spine injury and when we bought my wife's Boxster (with 996 seats) I wanted to rush to the ER with back pain after driving it for more than 50 miles. I swapped out the seats for some nice 997S seats and its a huge difference. If you can get the GT3RS seats Porka mentioned it would be even better. Good luck and enjoy the car!
I have no issues with my seats but I do have lower back issues. I stretch my lower back evey morning. Simple bend over and touch my toes. Boy does this help. I have had my lower back go out 4 different times. NOT fun.
if clutch is tight it is imperative to maintain such distance so your leg would be still slightly bended when clutch is fully depressed and also make sure your body is secured tight when you press clutch and does not turn.
as simple solution as it is - this little device helps to secure you to the seat pretty well:
http://www.amazon.com/Lock-Performan.../dp/B0010E7OB8
Congrats on the new ride. Time to change those seats? BTW... not sure if this helps but a chiropractor might help ease the pain. I also do streching in the mornings,etc... kinda OT
