Engine Vibration when A/C is engaged
Morning all,
I am experiencing a mild engine vibration only when the a/c is active. My Indy suggested I start with the motor mounts since one seems to be broken. No codes or any other indications that another system is the root cause. , I thought it wise to consult the group before I start swapping parts. Any thoughts on the source of the vibrations and what I should check.
Replace both if one is out as the other soon will be.
Great suggestion. I hadn't thought of the MAF. Our Toyota really vibrates when we turn on the AC and I have tried everything mechanical- simple cleaning may do the trick. Darn thing is a CPO as well, but the stealer is useless.
So, the next question is should I replace with stock or aftermarket? I will not track the car, so I'm leaning towards stock replacement from pelican. Thoughts????
Will give it a cleaning today before I purchase parts. Who knows, I am not 100% sold on the "bad" engine mount idea from my Indy. Is there a definitive test or visual inspection for a failed or failing engine mount?
I'm ready to pull the trigger on engine mounts but need suggestions on a few things. Should I replace with stock or upgrade to something better? and where should I purchase? Suncoast, Pelican? No plans to track the car if that helps with suggestions.
