Sprint Booster installed - initial impressions in post #1
#32
Unfortunately r1de23, its not something that you can pick up in a video its something that you will full grasp once you install the product. You can ask just about anyone who owns a Sprint Booster. Once you step on the gas, there is no doubt in your mind something is different and you will really start to enjoy your vehicle again.
#33
on the street sprint booster set to hi.... eg, stop and go traffic, the throttle is too sensitive at initial touch of the pedal... the car takes off, so you back off, but slows down to much, back on the throttle, car takes off....etc. then the car starts to oscillate.... in other words, hi setting in traffic makes smooth driving difficult. No big deal though, just shut the booster off to use factory settings. When the car is moving @25mph, hi setting is just fine... ideal on the track IMO.
#34
I think they used to call it "chipping". ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
A bunch of companies offer rewritten ECU maps. GIAC used to be the favoured brand around here. Essentially, programmers tweak the timing and fuel/air across the range of throttle positions from what the factory decided they should be. The new maps are loaded into the ECU via the car's OBD port. Usually, it's possible to pick up a few low-hanging horsepower this way by removing some of the margin of safety the factory built in for fuel quality and variable octane levels, and by deviating from the settings required to meet the EPA's urban drive cycle standards. The better ones can also change the way the engine responds to throttle (by which I don't mean throttle response) by how they manage fuelling, and my experience was that this helped my e-gas 'flat spot'.
Most people find this upgrade expensive or even a waste of money, considering that the butt dyno ROI is pretty negligible. It tends to attract a lot of debate of the "why do they think they're smarter than Porsche?" variety (which is silly. Porsche isn't stupid, they just have to deal with a lot of liability, regulatory and warranty exposure issues that a tuner doesn't). I chose mine to get the most out of my other engine mods - CAI, plenum and exhaust - which most people think is a reasonable excuse to get it done.
#35
Hey guys, wanted to chime in here. We have done a ton of ecu maps and sprint booster installs. Typically, someone does one or the other to begin with and then ends up doing both. They compliment each other well. The car is much more fun to drive adding the Sprint Booster and on Turbos, gets a ton more power reflashing the ECU.
We offer money back guarantees on both products so that you can try it out in confidence knowing it can be returned. However, be careful if you are not ready to spend the money because we have not yet un-chipped a car or removed a Sprint Booster![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
IMHO, the Sprint Booster is a more noticable upgrade and is half the price of an ECU remap.
Stephen
Stephen
#36
#40
fwiw, I installed the Sprint Booster on my '03 996 C2 MT yesterday. Yes, I can feel the more aggressive throttle mapping. My early, lighter weight, manually fuel injected 911 seemed eager to accelerate. The 996 merely seems willing. Will try to spend more time out on some back roads to see if I get any of that earlier sense of eagerness again with the SB.
I was mostly looking for better low end responsiveness for heel & toe. Often (in stock form), when I roll my foot over onto the accelerator, I get almost nothing. That changed a little -- not much. With a more aggressive throttle slope--the differences are greater, at higher throttle settings. Maybe over time I'll find a sweet spot to get the response I want.
Conclusion:
It's ok. It's easy to live without, especially at the price. I can see how some like & prefer it. But, it's hardly the amazing transformation that some have claimed.
Conclusion:
#41
[QUOTE=RF5BPilot;8357929]
I was mostly looking for better low end responsiveness for heel & toe. Often (in stock form), when I roll my foot over onto the accelerator, I get almost nothing. That changed a little -- not much. With a more aggressive throttle slope--the differences are greater, at higher throttle settings. QUOTE]
Which model did you get? there is an automatic and manual version. we sometimes interchange them to get more or less responsiveness based on the client's preferences.
#42
I have the "automatic version" from the first week it was available for our cars. There is a manual version?
A little jumpy cold out of the hole but throttle response is much better.
#43
I don't know if it's my small feet but I really hate the response I get when trying to heel/toe. I haven't yet tried using alternative adjustable pedals yet though to see if that would have any improvement.
I'm still on the fence about this product though as I don't track it enough to warrant the cost/benefit of this item.
#45
For me, I think the biggest advantage would be in heel/toe and even so only in track conditions where it can really count.
