Tire question: difference between pilot sport N1 and N2 ? -- now tire rubbing issue
I see tirerack has 3 types of Michelin pilot sport
- n1 -> $309
- n2 -> $371
- nothing -> $329
I also see at discoutn tires a bunch of other references..
http://www.discounttire.com/dtcs/tir...35&ar=35&rd=19
... which one to choose
and why
- n1 -> $309
- n2 -> $371
- nothing -> $329
thanks for the info on N1 N2... good to know ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Ok so now I have more problem... I just mounted the wheels I just received, front tires are dead that is why I asked about the tire information, I need to buy new one.
But I have rubbing issue in the front fender liner. Here are a couple of pictures. The clean stain at the bottom show the rubbing. the clean stain a little higher was made when I turned the wheel while still on the jack stand.
So the front tire are 235/35/19 and the rims are 19x8 - offset 46
Any advice ?
- can the fender liner be pushed forward a bit ?
- would narrower tire size help ?
Any advice ?
I had Toyo T1R's 235/35/19 for 4 Years at Fronts, they did not Rub... I just got Perilli Rosso 235/35/19 and they Rub like yours... Every Brand of Tire, even tho its the same size, its not actuly the same size...
No clue......tires might be too big? Are these used wheels and did they come off a 996 NB? Do you need spacers? And WTF is up with that voodoo doll in the upper right hand corner of the last pic? Like the color of your car.
The voodoo doll is protecting the car...until next halloween, where it goes back on duty...
Those are used wheels indeed, no spacer. The wheels are nicely fitted to the car, not too outward, not too inward. I am just surprised as everybody says there is no rubbing with 235 wide tire on 19 inch wheels..
may be I'll have to go to 225 as the michelin pilot sport might be wider than others... I still wondering if I go with michelin pilot sport anyways. as those wheels are for show only, i have my set of 18 carrera sport for auto cross and such.
I might get sumitomo III instead. also I have some 295 /35 in the rear and I want to get into 295/25 to get closer to the original ratio. I love the wheels just wished they would not rub...
I cross my finger as may be installing my row-m030 will solve the rub as well.
Zookie, is your car lowered ? looks pretty low on the avatar![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I see that the fender liner gets a little more curvy a few inch higher up, that might be enough, but it looks like i need a 1.4 inch clearance.
Anyone tried to push the liner using a heat gun ?
Sort of...
When Porsche manufactures a car, tire companies submit their tires to Porsche for testing. If the tire is approved as initially submitted by the tire company, it receives approval in the form of an N1 rating; the 1 signifies the version of the tire approved (the first version). If Porsche does not approve the tire, it makes recommendations to the tire company to modify the tire. If the tire company chooses to make the changes and submits the second version of the tire to Porsche and it is approved, it receives an N2 rating; the 2 meaning that the second version of the tire is approved and so on and so forth.....
The number after the N corresponds only with the version of the tire approved by Porsche.
So I'm guessing the N0 code is for tires never submitted to Porsche??
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Sort of...
FYI http://www.tirerack.com/tires/tirete....jsp?techid=26
"Production tires that have passed all of the tests and received the engineering department's release can be branded with an N-specification. The N-specification brandings include: N-0 (N-zero), N-1, N-2, N-3 or N-4. These markings on a tire's sidewall clearly identify them as approved by Porsche for their vehicles. The N-0 marking is assigned to the first approved version of a tire design. As that design is refined externally or internally, the later significant evolutions will result in a new generation of the tire to be branded with N-1, N-2, N-3, etc., in succession. When a completely new tire design is approved, it receives the N-0 branding and the succession begins again."
Any advice ?
Any advice ?
thanks
yeaaa noooo, wrong... It means Revisions or Improvements... There are N0, N1, N2, N3, N4 for Mich Pilot Sport Cup Tires... So you are saying Porsche Dis-Approved this tire 4 times yet it was put on every GT Car... okayyyyyyyyyyy
About the headlight cover, they are ebay. I think they are easy to find, simple film cut to size. A pain to install, still some bubble but too small to see unless you get your face on it. Still I manage to do it with a simple hairdryer... Once the film was on, I got audacious and decided to cut the middle of the film with a blade, following the line that is on the headlight cover. I tired to press really lightly to not mark the headlight cover itself.
If I had to do it again I might buy more expensive film that can actually protect the headlight. the ebay version are like window tint thick only. I'll try to post better later.
Anyone got idea for my tire rubbing issue
Good new, after a little test drive the rubbing is apparently only at almost full steering lock and doesn't seem to be a problem while driving.
Still I wish I could have no rub even at full lock, I hate to think that my car is 'limited'
