996 Forum 1999-2005
Will 997 "Lobster Claw" fit C4S?
Old 01-23-2011, 12:04 PM
Peedster
Peedster's Avatar
Default Will 997 "Lobster Claw" fit C4S?
Hello,
Will 997 Lobster Calws with this spec fit a 2004 C4S?
2 : 11 J x 19 H2 ET 51 : 99736216200
2 : 8 J x 19 H2 ET 57 : 99736215601
And are they 997S wheels or 997 C4S?
Tyre sizes are 235/35-19 - 295/30-19
Best regards
/Peter
Old 01-23-2011, 12:06 PM
100plus
100plus's Avatar
yes they will fit
Old 01-23-2011, 12:26 PM
Peedster
Peedster's Avatar
Thanks!
Is this a direct fit or do I need spacers?
/Peter
Old 01-23-2011, 04:21 PM
redridge
redridge's Avatar
they come from the 7C "S".
Old 01-23-2011, 04:29 PM
ivangene
Parts Specialist
ivangene's Avatar
so do the 997 C4S use 11.5 - 12" wide rear wheels?
Old 01-23-2011, 04:40 PM
redridge
redridge's Avatar
they still use 11".... but tuners have made 12" wheels for them, even on the 7NB... btw the 7C2 "S" is considered NB. 7C4S is WB.
Old 01-23-2011, 04:42 PM
ivangene
Parts Specialist
ivangene's Avatar
thats why I asked... so the above widths are 11" rears for NB - unless I read that wrong or you missed it....
Old 01-23-2011, 04:56 PM
redridge
redridge's Avatar
The OP asked if it will fit a 04C4S.... stock 11", et45 (wb), lobster claws are 11", et51(nb).... though it is a NB.... the 7NB is wider than a 6NB but not as wide as as the 6WB.... so yes, it will fit, but will be in the wells about 5mm or so from stock 6wb wheels..... OK now im dizzy.
BTW.... nice new avatar, love the contrast!
Old 01-23-2011, 05:07 PM
ivangene
Parts Specialist
ivangene's Avatar
thanks!
OK agreed 997S (NB wheels) on a 996 C4s (WB) are both 11 inches wide in the rear
Q:
If the 997S (NB) uses 11" wide rears, do the 997 C4S (WB) cars come with something wider than 11" (like 11.5-12 or wider) - not trying to make it difficult... be it's just what I do best
Old 01-23-2011, 05:19 PM
balefire
balefire's Avatar
Originally Posted by Peedster
Thanks!
/Peter
Both front and rear will fit without spacer, but adding a 5mm or 7mm spacer will make the offset closer to stock on both the front and rear.
Old 01-23-2011, 05:20 PM
redridge
redridge's Avatar
Originally Posted by ivangene
thanks!
Q:
yes.... just recently though, gt2rs is 12", though they are 19". The 2010 WB are still 11".... I believe the tires havent caught up with the wheels yet.
Old 01-23-2011, 06:16 PM
ivangene
Parts Specialist
ivangene's Avatar
interesting
Old 01-24-2011, 04:01 PM
pissedpuppy
pissedpuppy's Avatar
sorry for this stupid question, but why are they referred to as "lobster claws"?
Old 01-24-2011, 04:23 PM
redridge
redridge's Avatar
just look at 2 spokes..... see the claws.
Old 01-24-2011, 11:24 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Actually, they are more acurately known as "Lobster Forks" not Lobster Claws. Look at the end of one spoke, it looks like a lobster fork (left and right in pic).
Quick Reply: Will 997 "Lobster Claw" fit C4S?
