Real or Replicas?
Poseur
Look for the OEM Porsche logo on the wheel. Only OEM wheel suppliers are Permitted to put that Porsche part logo on their products. And don't forget to retorque all of your front and rear suspension components several times a year. Otherwise, you risk catastrophic failure of the suspension. The 996 is not designed to handle the stress of a 19 inch wheel/tire.
I thought it was designed around the 25" rad of the tire.... not so much the wheel.
Parts Specialist
yea, I'm not sure I believe 19' will tear all your bolts loose any more than 18' with the same overall 9within reason) diameter tire..
some track doods might have data but my guess is that unless you track it hard and heavy you wont be seeing bolts fall out
Damn those 19's!
