996 Forum 1999-2005
Correct Tire Pressure?
Old Jan 17, 2011 | 02:22 PM
norcoastal's Avatar
norcoastal
Default Correct Tire Pressure?
I've looked at this site and found many people saying that the correct tire pressure in the cold is 36 and 44 front and rear respectively.
Then how come my BF Goodrich g-force tires say 50 psi max?
I know...it sounds like a stupid question.
Old Jan 17, 2011 | 02:38 PM
LVDell's Avatar
LVDell
Your tire has a max psi but PAG/PCNA has determined what psi works best with our cars. Different applications require different psi.
Old Jan 17, 2011 | 02:51 PM
rwiii's Avatar
rwiii
As Dell says, the max for the tire is a catch all for all applications from the tire company. The auto manufacturer makes a reco for the specific car and wheel/tire size. It should be on the inside lid of your frunk.
Old Jan 17, 2011 | 03:08 PM
norcoastal's Avatar
norcoastal
Got it. I checked the inside of my gas door and found it there.
Thanks guy's!
Old Jan 17, 2011 | 04:50 PM
Zookie's Avatar
Zookie
FYI according to the Latest TSB from Porsche regarding Tire Pressures... Correct PSI is 33F & 36R Half Load and 36F & 43R Full Load... I ran Full Load Pressure all Last Summer and my tires got Cupped because of Over Inflation... I now run Half Load PSI and Ride & Handling is much better...
The Info inside your Gas Door is Full Load Pressure
Half Load = 2 Passengers Only
Full Load = 2-4 Passengers + Luggage
Old Jan 17, 2011 | 05:10 PM
norcoastal's Avatar
norcoastal
Interesting, thanks
Old Jan 17, 2011 | 05:27 PM
LVDell's Avatar
LVDell
I have messed around with various pressures and I like to run 36/38
Old Jan 17, 2011 | 06:44 PM
BruceP's Avatar
BruceP
Interesting. I wonder what the logic of this is, given that loading up this car relatively biases weight to the front.
Old Jan 17, 2011 | 07:10 PM
Zookie's Avatar
Zookie
Originally Posted by norcoastal
Interesting, thanks
Sure is, these TSB are on Renntech.org for Paid Members
Try a 6 Hour Trip to Montreal(F1) from Toronto with Two 200lb Guys in the Front and two 120lb Girls in the back with Front Trunk Full, Two Water Cases on the Back Deck and a Full 40+lb Bag on top it gets Heavy :P
No pix of teh Bags on top from the Trip but one just before the Trip
Trust me when Porsche says "Full Load" Pressure, it means what it Means
Old Jan 17, 2011 | 07:13 PM
sparks259's Avatar
sparks259
1#per 100# car weight+2-4# for engine.
good baseline starting point
Old Jan 17, 2011 | 08:08 PM
Pac996's Avatar
Pac996
Because 50 lbs is the MAX pressure for any weight in the car
Anyway just joking around. If you dare to try putting 50 all around and flying some corners. hehehe see yah at both car and hospital body repair departments. 50 would be too stiff/slippery in turns.
Old Jan 17, 2011 | 09:12 PM
C4CRNA's Avatar
C4CRNA
Two 120lb girls in the back for 6 hours!!! Impossible!
Old Jan 17, 2011 | 09:31 PM
Zookie's Avatar
Zookie
We had to stop several times... Apprently girls cannot go 2 hours without emptying their Blader, this year is "Guys Only" F1 Weekend
Old Jan 18, 2011 | 07:37 AM
norcoastal's Avatar
norcoastal
I changed the tire pressure in the rear tires and my tire noise got so much better. They had too little air.
Old Jan 19, 2011 | 10:19 AM
ivangene's Avatar
ivangene
Parts Specialist
too little air.
personally I have NEVER been accused of that
