MaxJax Lift Anchor Type
TomF,
I know that there is a discussion about sleeve vs. straight epoxy vs. hybrids vs...
The MaxJax supplied sleeve Wej-Its worked well for me in the 7.5 " thk 4000lb reinforced concrete used in my garage floor. Others have had major spalling/breakout problems both above and below the floor when using sleeve or wedge anchors. All that I can say is YMMV??
My point exactly, just saying use epoxy doesn't make it right It should be more like- use the right materials. Just as important is "what concrete is the floor made of."
TomF,
If one really wanted to be safe, pouring new pads reinforced with steel and "j" or "l" bolts tied to the steel would be the way to go. I am probably going to have to re-pour my slab (or pads) when I install my lift as I am pretty sure the depth is inadequate.
Cheers,
Tom
All points well taken. You clearly know your subject. The quality of the concrete has a huge impact on the success of the anchor retrofit. Your slab is what my garage slab aspires to be!
Cheers,
Tom
Cheers,
Tom
Hilti has a tech library for anchoring to concrete: http://www.us.hilti.com/holus/page/m...ctedOid=-60251
I'm a structural designer in the oil and gas industry and we specify epoxy anchors all the time for anchoring heavy equipment and structural steel. Any anchor chosen will have to be used within it's design limits (duh) which is the most important point one should take away from this discussion.
If it were me, I'd just buy the kit from MaxJax and be done with it.
That is very interesting. Maybe I am calling them the wrong thing- I am talking about the j-shaped bolts that hook under and tired to rebar... I am surprised that they could pull out in any circumstance. I would expect the bolt itself to fail first. What is now the strongest? I am assuming that it is an embedded strap of some kind...
The standard anchor bolt used in industrial applications is A36 steel (ASTM spec is A307) with a threaded portion at the bottom with nut/plate/nut secured by welding or simply damaging the treads so the nut cannot turn. The plate can be a simple washer or a square plate.
See pics of really big ones: http://www.pipingtech.com/blog/categ...-bolts-embeds/
You shouldn't need ones that big for your lift! The most important point is an anchor bolt must be designed for the application and load. If it works, fine.
