996 Forum 1999-2005
aftermarket warranty for 996
Old 12-22-2010, 01:47 PM
SLC1973
3rd Gear
SLC1973's Avatar
Default aftermarket warranty for 996
First time here. I am considering purchasing a 996 (1999, 46K miles). Here is the car I am considering, any opinions are welcome
http://www.harrisonimports.net/used/...eHistory=true#
I have read about all the engine problems these cars have so I won't buy the car unless I can find a warranty plan that will cover everything, especially an engine replacement. I know most aftermarket warranty companies are just out there to get your money so I am looking for suggestions on companies you've had good experiences with. Thanks!
Old 12-22-2010, 02:21 PM
roadsession
roadsession's Avatar
It is highly unlikely you will find any reputable after market warranty company that will insure a car that old.
In 2009, the cut off for Fidelity was a 2002 and 50,000 miles.
Old 12-22-2010, 02:26 PM
Thundertub
Thundertub's Avatar
Cool
... and yet, on TV a couple weeks ago a company was advertising to cover for older cars and higher mileage than stated above. I cannot vouch for any of them, but they could be out there.
Caveat emptor
Old 12-22-2010, 02:29 PM
2K7TTMIA
2K7TTMIA's Avatar
to the OP, welcome; What sort of price range are you looking at for a 996 variety? that red 996 is pry worth closer to $15-17K right off the bat.
IMO, that car has seen better days, you're better off going a little newer or at least with a Pcar that has better documentation and care. If you are dead set on a warranty, then you need to consider paying a bit more. Easycare has been mentioned here for aftermarket coverage; won't hurt to make a call.
Old 12-22-2010, 02:54 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Interior looks a bit rough for the miles, no?
Old 12-22-2010, 03:17 PM
roadsession
Easycare doesn't cover Porsche 911's last time I checked.
Anyway, I think you should do a search on "Aftermarket warranty" on this forum.
Good luck
Old 12-22-2010, 04:00 PM
SLC1973
3rd Gear
SLC1973's Avatar
Thanks for the replies. My budget is quite limited, up to 25K. The problem is the market for used 996s here in the Salt Lake area is very limited. Thanks for the easycare suggestion as well, I will give them a call.
Old 12-22-2010, 04:25 PM
Marc Gelefsky
Super Moderator
Why limit yourself to Salt Lake, look further and find the best car.
Old 12-22-2010, 04:47 PM
SLC1973
3rd Gear
SLC1973's Avatar
I thought of that but what's the recommended procedure: Find it online, have a mechanic check it out then fly out to test drive it if it all looks good?
Old 12-22-2010, 05:06 PM
francars
francars's Avatar
+1 on that
Old 12-22-2010, 05:08 PM
francars
francars's Avatar
Based on your location why not check out Bay Area, CA? There are a few better examples at possible lower cost shipped to you. Actually you can buy and drive home, well not sure with the weather these days
Old 12-22-2010, 05:33 PM
Marc Gelefsky
Super Moderator
Originally Posted by francars
+1 on that
Look how cracked the leather is. Kind of looks like the passenger seats lower bolster was dyed.
Old 12-22-2010, 08:49 PM
Sneaky Pete
Sneaky Pete's Avatar
For the money you have to spend you can get a newer car. I would throw this back to ocean. Like Marc said increase your search area. There are cars coming out of the woodwork. Good luck!
Old 12-23-2010, 04:10 AM
MetBlk 911
MetBlk 911's Avatar
The word "hammered" seems more appropriate. How do you get an interior to look that bad with only 46K miles?
Here is the interior of a 53K mile car I just picked up for $24K
Quick Reply: aftermarket warranty for 996
