standard front seat back cushion pad removal method?
hi Guys - Does anyone know how to pull off the cushion in the backrest of the standard 996 front seat? I can pull the middle section of the cushion about 1-2 inches out to look back there, but how does it disconnect to be removed in entirety as the top and lower portions are firmly attached somehow? I searched here, 6speed, and renntech but didn't see how it was actually removed without causing damage!
Thank you!
Thank you!
Got it... just like everything else on the 996... just pull! It comes off by pulling upwards on the top section of the cushion to unlatch the top white plastic catches... bottom section I didn't need to take off, so I don't know how that comes off.
