Rev limiter Hit
#31
My '84 911 with a higher numerical rear-end ratio would get to the redline in 3rd gear between Turns 8 and 9 at Watkins Glen each lap. I didn't want to upshift into 4th for 1 second and have to downshift for Turn 9, so I would just let the engine speed be checked by the rev limiter.
I did this for YEARS. The car now has 130+K miles on it, of which probably 40K at least are track miles.
The engine has never been out of the car. No valve jobs, rings, zip.
Bumping into the rev limiter didn't hurt the car at all.
Cool story!!!
A good friend of mine has an '84 911(Turbo look) and I absolutely love that car. In fact it was the first P-car I have ever driven and I will never forget that experience.
#34
Furthermore, your anecdotal evidence, plus the fact that your only proof its not harmful is that the engine hasn't blown up yet doesn't amount to much.
#35
Follow-up to Quadcammer:
I did have a leakdown test done. The results (at the 120,000 mile mark) were within factory spec for a brand new engine.
So, yes, this is just one data point from one guy, but it implies that hitting the rev limiter does not harm the engine. I sure did it a lot, and so far at least the engine does not seem to have suffered.
#36
I'm not sure where all this heat is coming from, Quadcammer. The rev limiter is an ECU function, not a physical barrier. These engines are made for high rpms; they suffer much more from the opposite kind of use, it seems to me. And I have trouble imagining that Porsche would go to the trouble of programming the engine to cut fuel at a certain rpm, and then choose an rpm that produces engine damage.
This runs the risk of becoming one of those debates in which the absence of evidence just serves to dial up the rhetoric. Me, in the absence of evidence, I just default to common sense...
#37
Obviously tapping this thing on occasion is not a big deal. Thats why its there. Holding the car on the limiter is simply not a good idea. Thinking about the harmonic issues alone caused by cylinders essentially misfiring at max rpm for 20 seconds at a time makes me not want to do it, but use whatever common sense you want.
drive your car in 1st gear banging off the rev limiter for the next 20 years if it makes you happy...but I sure won't.
#38
#40
Obviously tapping this thing on occasion is not a big deal. Thats why its there. Holding the car on the limiter is simply not a good idea. Thinking about the harmonic issues alone caused by cylinders essentially misfiring at max rpm for 20 seconds at a time makes me not want to do it, but use whatever common sense.
#41
Scenario 1:
You are an enthusiast. You regularly accelerate briskly and hit the rev limiter for a millisecond before shifting (i.e. you do not hold the car on the limiter)
Scenario 2:
You are on the track. Your gearing is not optimized for the track. You decide to let the car bang against the rev limiter for 10 seconds/lap (i.e. literally keeping your foot to the floor while the rev limiter limits the rpm for 10 seconds).
The first scenario is absolutely fine and will not cause any damage. hit the thing momentarily as often as you want.
The 2nd scenario, while probably not resulting in immediate damage, is not doing your engine ANY favors.
#42
Bruce, like I've said several times, thats perfectly fine. Its the act of holding the car against the limiter that is the problem.
