error code P1325
I posted this on the wrong form, sorry. I moved this post over to the 996 turbo form.
I'm getting a P1325 on a 2001 996 turbo 24,000 miles. I seem to get the code on light acceleration (under 3000 rpm). I have swapped out both actuators on the bank 2 side with the two on the bank 1 side and the problem stays on the bank 2 side. It there any other troubleshooting I can do with the motor still in the car? thanks,
Joel
Joel
Last edited by joelesmith; 11-12-2010 at 12:14 AM. Reason: this should have been in 996 turbo form, sorry
If its the durametric its got a warning that when operating the car some numbers aren't dependable. Its seems primarily a read at idle program and retrieve sodes already received. I'm not sure about the race car version.
WHich type of reader are you using?
