other cheap way for a Ln IMS retrofit kit?
Always I have a mechanical problem, I investigate and study all the possible solutions. I'll go to make this work alone like the spanish user barracuda.
So, once I've find the solution of insert an aftermarket bearing is not possible, I would insert the Ln retrofit.
Basic Sponsor
Thanks! You can see the kit here:
http://www.pelicanparts.com/techarti...ft_Bearing.htm
-Wayne
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
Yes, our kit is currently undergoing testing in our test car (1999 996) and is working flawlessly. We had to pull the engine out to do some tech articles for the next book (101 Projects for your Porsche 996), so we've had to stop testing it. I hope to have the engine back in before Halloween, and then back on the road. I hope to have the kit available and in the catalog by the end of the year, or the early part of 2011 at the latest.
-Wayne
-Wayne
http://forums.pelicanparts.com/boxst...ml#post5596657
I went with the LNE solution.
JP
Basic Sponsor
That said, the ceramic bearing *should* last a very long time - much longer than the original bearing. BUT - no one really understands 100% what the mechanism is behind these bearing failures, so at this point, it's still just a guess (a very educated guess).
With the Pelican kit, we've designed the kit to be an inexpensive 30K replacement part that you simply swap out during a clutch change. For those who want the more bulletproof solution, I suggest that you go with the LN Engineering kit. We're not planning on offering the special ceramic bearing with our kit right now.
Hope this info is useful!
-Wayne
Hello heiwaz.
Welcome to rennlist board.
I've seen that you're lurking what to do (here and in soloporsche).
IMHO I think this is a very important operation and the target is to prevent an engine failure. I wouldn't look for a cheap solution. The meaning of cheap is not always in the same line as effectiveness.
If Insaro is expensive for your budget, LNE offers an accurate and good priced double row bearing Kit. It's provided with an hybrid bearing similar to SKF (barracuda's solution). I think It's a fantastic solution and the cost (595 $) is a good price.
Think that you'll have to pay spanish duty import taxes, and spanish VAT (18%).
If I were you I'd purchase a magnetic oil drain plug, and the spin on oil filter adapter + oil filter too.
New oil = you'll need almost 10 l. (if you want to use a good oil brand send me a PM and I'll help you to locate the best price). Forget Mobil 1 0W40.
In BITOG you?ll find a huge info about it.
But you'll be saving labour cost as you'll do it yourself, so the total amount won't be expensive thinking about the importance of the solution.
Going for barracuda's solution is not easy with double row bearing.
For those who were thinking that heiwaz came here to sell something, you're wrong. He is a soloporsche user and I know him.
http://soloporsche.com/member.php?u=3464
Besides I think that It's very important to follow Navarro's oil advises. As your car is a MK1 unit, try to contact to Navarro or Raby. Thay could recommend you the best parts for your car including billet chain tensioners.
enjoy rennlist
regards from Spain
regards from Spain
thanks juankimalo, it's grateful to see a spanish user in this forum. I was talking by telephone with barracuda and he explain me with all of detail his operation with IMS, and why can not use his solution on my double bearing. Maybe I'll install the Ln kit.
