BRAKE UPGRADE
I would like to improve the braking of my carrera 2 345 hp, with discs front and rear amggiorati. I would not change the calipers with those of the turbo not to have to change too many pieces, someone produces front discs 330 340 28 mm thick, but like the original? At the rear you can mount the disks of turbo 4s without changing the calipers?
The former commercial adviser from FVD in Germany is now my friend's wife.
She told me to purchase the Trickstuff pads in FVD
She is a real expert and knows the whole references in FVD
Similar performance to Pagid and cheaper
http://shop.fvd.de/de/en/Porsche-0/9...Racing%22.html
Does that really help anything?
Here's what I'd always understood: Brake cooling ducts rely on venturi effect to work. Thus, cars that are driven faster get bigger ducts because they'll be moving more air. But a bigger duct on a car that isn't driven fast actually does a worse job of cooling the brakes (assuming a situation in which a street driven car would have that problem). Not so?
Ale-Superbike:
What problems are you having with your stock brakes? Let us know what you are trying to fix, and we can help.
If you are just looking for a visually-impressive big brake kit, that would be good to know too.
Hello I use the car on the street and some track time. I wish I had more problems with fading, (Pagid yellow tubes) and a larger hard drive without changing a clamp to heat dissipation and eastern part.
