Coolant Reservoir removal MY02
I am trying to remove the coolant reservoir in my 02 3.6. Seen some of the threads describing removal for the 99 3.4s, and one thread discussing slight variations for the 3.6, but I'm stuck.
https://rennlist.com/forums/graemlins/banghead.gif
I have lowered the engine as far as I can and I still don't have enough room to pull out the tank. I have moved the tank about 3" towards the engine but cant move it down and out of the bracket that holds tank to the car.
Anyone have any tips?
Many thanks,
Many thanks,
Glad u got it out.. I had to remove two gas lines if I remember..but be careful not to break the sensor on the bottom especially since it's the weekend and the p dealer is closed... Broke mine bu lucky it was a weekday and it cost less than $20.. Don't forget to burp ur system when ur done..
This is one repair job I would have gladly paid my indy to do. I now understant why others had to curse so much during the job. I did the same. Absolutely worth paying the extra 4/5 hours in labor or whatever they would have charged. Having said that, I put this down to experience and learning that will hopefully stand be in good stead for the next DIY job.
Per above posts, my undersanding is that MY99 are easier given the smaller tank. But for my 02, I had to lower the engine (you may not have to do this for a 99) and, in the end, take a nut (or some kind of cap that screws onto the end of the fuel line) off one of a fuel line to get the old tank out and the new tank in. Took me the best part of the day, but would have been a LOT quicker if I had takend off the fuel line nut in the first place. Would not have been able to do it without all the tips and posts on rennlist and renntech. Thanks all
Good Morning guys -
I am looking to tackle this one today on my '04 996. One thing I am having a problem with is locating/removing the fuel lines. I only see one cap on the fuel rail at the rear of the engine. I removed it, but the fuel rail/line that it is attached to is firmly mounted, and I don't see any easy way to pull the rail itself. Is it just the cap that as to be removed?
I have not lowered the engine on its mounts yet - maybe that's part of the problem?
Any additional tips/advice would be greatly appreciated. Looks like getting this in and out is a lot tougher than I first thought.
Rob
Rob
Coolant Tank-while you're in there
In re. 996s especially, when replacing the coolant tank also replace the coolant level sensor (about $40 from dealership). So easy a cave man can do it...once the tank is removed.
relinuca
relinuca
Thanks HurdiGurdi - I watched that video, and it's great but it doesn't show anything about the fuel line itself. Appreciate you digging around for it though
Will consider that sensor relinuca - good idea.
Anyone else who has done this, or removed that driver side fuel line, I'd greatly appreciate some insight!
Rob
Rob
I'm with Hurdi (I know right ?) that music is brutal....but it totally goes with the guy's pants.
I didn't watch the vid all the way through...but that's not a 3.6 I don't think. When I did mine (twice now - in two different cars) it was pretty much necessary to lower the engine. I don't recall having to deal with any fuel lines...but that doesn't mean I didn't. My memory is like the music in the video...crap.
There's no way to sugarcoat this job in a 3.6 litre car. It sucks. The tank will absolutely come out eventually, but you're working blind and it's pretty non-intuitive. I imagine if you do this for a living you would get a knack for it, and the tech I know says it can be done without lowering the engine but for a one-time DIY job....ugh.
I replaced the cap the second time but never the sensor. The cap has gone through a number of revisions IIRC
