I need to get between -1 and -2 degrees of camber on my 996 for the track next weekend. Current setup tearing up front tires on certain high speed corners.
adding a ton of neg camber might help but there is more at play here than just that....you post that in the racing section and see how they treat the comment
My 02 996 stock suspension, max 3/4 degrees negative up front. Without boring out the strut bolt holes or buying aftermarket strut mounts, that's about all you can expect. For autocrossing, I add 1/4" spacers up front and pulled the rear toe-in to the minimum factory recommendation (almost 'straight up') and that helped tremendously.
Yeah seriously, if I wanted to go racing I would buy a race car, just now I'm happy with DE's but not happy about the stock setup and the tire wear on my Nittos. So the next option is camber so the whole tire gets action. From what I've seen so far I could spend up to 5k on getting parts for this, that I don't want to spend. If it turns out I need to spend 5k on camber then the nittos just became a perishable item in my eyes
Yeah that's the max I was expecting, I've looked at the aftermarket mounts and the $$$ keep adding up.
I was wondering if anyone else had done the same upgrades and if so what did they purchase
Just grab some lower gt3 control arms and some shims. Around $500 (memory might be off on price). Can get plenty of front negative camber and a slightly wider track to boot. Rear can get plenty without mods.
But, you need a bunch more suspension bits to do it right. When I'm on a computer and not this wacky iPhone I'll point you in the right direction.
Sean, I think you have the answer right there!
After getting those wheels and putting my name on a set of cats, I will be wearing out the Sumis next weekend before trading up to the nittos in October.
As it's already been stated, GT3 lower control arms are the ticket for your setup. I'm not quite sure they're as cheap as $500 for the whole setup these days but it's money well spent either way.
There's also camber plates on the market. I think I saw a new manufacturer advertising in this section just a couple weeks ago. As a note however, they're all just copies of the factory upper monoball mount from the GT3 which can also be used on our cars and is cheaper than all the aftermarket mounts. I think GT3 mounts are like $150 each from sucoast. (search the GT3 section about rotating the top mounts for camber to see how this works). The real issue wtih the GT3 upper mounts if you're running everything else stock otherwise is your ride height might change by a few mm. I ran them on my 996 but with coilovers so height change wasn't an issue as I set height at the same time I set camber.
p.s. You'll really like the way the car drives with a little more camber in the front at the track. Starts to bring the front end to life.
Yeah new nitto's on order for next weekend since I cored the drivers side front last time taking 7 clockwise killed that tire.
-td
Thats one of the things my indy suggested before they went off on a $5k suspension upgrade pitch.
I've been all over the place with the C2, a couple suspensions, GT3 bits everywhere, upgraded brakes, seats, harnesses, and a bunch of other stuff.
I'm also in H-town, so drop me a PM if you want to chat. Or post here as I'm not the only one that went crazy on their C2 for the track. Depending on what you are looking at, I can try to point you in the right direction in terms of cost/benefit etc.
BTW, who is your Indy? You don't need to spend $5K for a good compromise suspension. Hell, you could get mglobes JIC-Cross setup for way less than that - and then you would be ready to go.
