Inductive RPM pickup - where?
Hypothetically, if I was going to dyno a 996, where would I hook the inductive RPM pickup up? Does it have a "loop" sticking out of the harness that triggers one of the coil packs?
I did a search and didn't find anything... but there must be a simple solution.
You can pick up RPM from the OBD port. Not sure if that is "inductive" per se, but when I did a dyno all they did was plug in an OBD sensor.
![Name: FILE0009.jpg
Size: 70.0 KB](https://rennlist.com/forums/attachments/996-forum/469922d1282834309-inductive-rpm-pickup-where-file0009.jpg)
-td
[EDIT: do a search for OBD and RPM (possibly in the GT3 section). I know some folks have picked up RPM for traqmate from their OBD port.]
-td
According to the Dynojet folks, their software doesn't allow an ODBII signal to be plotted as the horizontal axis of the chart... (which would be RPM).
I guess I have to see if I have the "EZ RPM pickup"...
Originally Posted by KLockliear@Dynojet.com
Typically, you can go to one of the trigger wires of the coil with a primary inductive pickup. Or you can use the EZ RPM pickup...or the optical RPM pickup. The OBDII datalogger does not allow you to read RPM and use it as a bottom graphing axis.
