Are 3.4 and 3.6 mufflers identical?
One of my mufflers is making a rattling/fluttering sound after an *ahem* spirited burn through the mountains.
I've located a replacement muffler locally from a 3.4 litre car. Will it bolt right up?
they are not the same.... the bracket mount have different location. You must use the 3.6 mount and bolt it on the 3.4 cans. On the 3.4 cans there isnt any accordian on the cat side pipes for easy alignment... as for sound, they are close but not quite. I would not mix match mufflers as it might have diff back pressures and can offset the balance of the exhaust... I would not take the risk, but that is just me.
