My new supercup exhaust!! :) *updated w vid!*
Hey, woo hoo! My new fabspeed supercup exhaust finally came! ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
just finished installing it... ran into 2 issues.. first it didn't come with tips like I expected.. I was expecting the 993 style tips to be on it...
I will email them in the am... but until then I cant get the pass side tip to tighten up... clamp is all the way closed... loose as a goose... redid it 4 times.. same each time... any tips? no pun intended?![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
![](http://inlinethumb50.webshots.com/6705/2600307290104806154S600x600Q85.jpg)
My TA sport exhaust flanged end-pipe would not connect to the OEM tips-pipe without a special ring that goes in between the 2 pipes used as a connector-type to seal and also to act like an adjustment tool for the tips. Without this ring in between, the clamp would not hold tight, connecting the 2 pipes. One end of the pipe, TA exhaust side had a flange design which is different than the OEM Porsche exhaust end-pipe design. I had to order those rings directly from TA authorized dealer in LA. You may need to contact FS and ask them about your issue... Good-luck.
Hey are these the ones they said they were going to fab up for $595 over on 6speed a couple of months ago?
This link? http://www.6speedonline.com/forums/a...-released.html
Did you retain stock cats or is this cat delete?
I got the from Fabspeed directly... they are loud.. but not as loud as I expected...stock cats for now... I cant drive the car right now because my driveway is in the middle of being repaved... argh!
I believe these are diff than the ones posted on the 6 speed forum...
and the 124.... I love it but alas... it needs more love than I can give it at the moment...
part number is non existent.. invoice says part # 000 996 supercup exhaust price $850 I believe this is the 2nd or 3rd set they have made.. they are looking into the tip issue...hope to hear from them tomorrow as I just got a reply a bit ago.
Thanks for the update, I'm curious. I thought I heard a rattle in one of my mufflers the other day, so if it doesn't pass the rubber mallet test this weekend I may drive down to Fabspeed and see what they've got.
