Does this sound like the infamous windshield squeak?
I've had the "hamster running squeaky wheel" for a few weeks. Traced mine to #10 in redridges post. The tab under the hazard area was where mine was. I moved the whole assembly around/pounded down on it/pulled it sideways/up and down for a few days. The noise disappeared and hasn't returned. That was 3-4 months ago.
Odd Posts
Let me know what you find... I may have the same issue.
Here are the pictures, I bought the adhesive backed felt at Walmart and have a ton left over in read, green and white, if anyone wants it.
Remove the a-pillar trim - it just pulls away (requires some force). Be careful when removing so as not to bend it too much and crease the leather
![](http://i480.photobucket.com/albums/rr167/fbgh2o/Dash%20Squeak%20Fix/IMG_1244.jpg)
Remove the center cover for the alarm readiness light (I pried it up, but be careful it's fragile)
![](http://i480.photobucket.com/albums/rr167/fbgh2o/Dash%20Squeak%20Fix/IMG_1246.jpg)
Gently use a flat screwdriver to lift the edge of the defroster cover where it butts up against the air vent housing.
![](http://i480.photobucket.com/albums/rr167/fbgh2o/Dash%20Squeak%20Fix/IMG_1245.jpg)
Slide you hand underneath to separate tabs and eventually the whole piece will pop out. I worked my way from the a-pillar to the center of the car. Lift away.
![](http://i480.photobucket.com/albums/rr167/fbgh2o/Dash%20Squeak%20Fix/IMG_1249.jpg)
Apply felt liberally to underside and around the tabs (sorry its black on back and a bit hard to see if anyone wants the full size picture, I can email it to you)
![](http://i480.photobucket.com/albums/rr167/fbgh2o/Dash%20Squeak%20Fix/IMG_1250.jpg)
Also attach felt specifically on edge that touches the a-pillar trim
![](http://i480.photobucket.com/albums/rr167/fbgh2o/Dash%20Squeak%20Fix/IMG_1251.jpg)
I would suggest placing felt anywhere the cover comes into contact with the hard polystyrene. I think that this a major source of noise. It might actually be easier to place it on the polystyrene than on the cover.
