Engine vibration at idle
Hello folks......,
How's your engine running.....mine is vibrate at idle just a bit.
The engine runs perfectly but you can feel the vibration
I replaced the engine mount, spark plugs and all the filter..
The vibrations are less then before but you can still feel it.
Is your engine runs the same
Robert
Robert
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Is your idle 800 rpm and or does it fluctuate any? if your idle is steady @ 800 rpms with no fluctiation, sounds like you have something loose ie dash or doors if your whole car is shaking check plugs clean idle air valve with electronics cleaner. If the problem occurs when you pull off from a stop maybe give car meor gas. If problem occurs when your stop press clutch earlier. hope this helps
+1, although theoretically an H6 is supposed to be completely balanced and smooth like the inline 6....but that's just theory
my idle never reached 800,, it always fluctuates between 600-700,,
is that a problem?
