Engine noise/click at idle, normal ? (video + sound)
#47
I ordered a new set of plugs and I soon as I get them, I'll get to it.
Yesterday I checked them out but I did not have the proper tool to screw/unscrew them, so I'll go today to autozone to try buying a spark plug tool that fits. It is quite narrow in there.
By the way, I see the ignition plug have blue glue on them, is it important to add some ? what brand you guys recommend ? Because I see the screw are like 1/5 of a trun to lock.
#49
I repeat, do not use antiseize.
#50
Sounds like a lifter or possibly a wrist pin bushing to me.. Lifters have 4 distinct sounds when they go bad, one of them is similar to this.
Most of the time lifters are just dirty, due to their design they accumulate a lot of gunk
#51
I don't agree. Go ahead and dont use it then, once you get a spark plug stuck in the head you will think twice next time. And yes you can use a torque wrench on the spark plugs, i did it a few weeks ago.
#52
The durametric sent me a cat conv. efficiency error code this time around. I assume this is the message about cat conv dead ? which would match my bank2 clicking noise, right ?
Now I just need to figure how to trigger the CEL light so I can get this replaced under warranty I was thinking of pulling the MAF, or is there another way ?
#56
How many miles on the car and how often was the car left to rott. I figure way low miles it might be varnish causing sticking. Exhaust leaks will sound like lifters and such and I don't think the long range life of spark plugs is geared to guys that want top power and performance. Even flattened lobes might be your problem or sticky lifters. Even combinations are possible. Best bet is change the oil and if it were me coming back to the car after a long sit I'd change the oil again after a week or two of spirited drivings. The plugs well be sure to keep tack of which plug comes from each cylinder and diagnose further for where bad performance from valves might be happening. The nasty thing to listen to is me wondering if valves got fried and or warped. Heat will also take the rebound out of springs leading to floating valves and the train clanking like that untill higher revs where things just float away. Anything is possible.
For sure change the oil and check what the plugs will tell you.
