Question about radiator cleaning
It is getting the bumper back on that concerns me !
Seems strange that I should be the only one with this seized Phillips screw situation. Maybe because I have a high mileage '99 C4 which has been winter driven, meaning more time and opportunity for rust seizures.
The final step was the flute flushing, and it worked very well. I just used a household cleanser, squirted into the rad and condensor flutes and flushed with a garden hose nozzle. Did this about 3 times until there was only clean water coming out. However, most of the flushing was done from the front. I could not get my handgrip nozzle up into the fan shroud area very well to flush from the back as recommended. Anyway it seemed to work, and I rinsed very thoroughly.
The final step was to use my shop vac in blower mode, to thoroughly blow all the water out of the affected areas.
Thanks to Macster and other for the good advice and tips.
