noisy power steering pump
I have a 2002 C2 with 147,000 kilometres. It has a factory reman engine installed at about 70,000 kilometres.
My power steering pump is noisy. It makes that typical whining/whirring sound and it's been there since I've owned the car. I have managed to ignore but at a recent autocross it started howling as I exited the stop box. Bad howl while turning the wheel several turns, not so much on less than one turn. Back on the road at normal operating temperatures later it settled down.
Now I can't ignore it so I have the following questions:
1) Anyone else have noticeable power steering pump noise?
2) Would a fluid change help me ? ( I was going to suck out as much as I can then refill it...turn the wheel lock to lock a few times to bleed any air).
3) What fluid is recommended?
Thanks gents. I have cross posted on Renntech.
jasper
jasper
crickets indeed.
Loren at Renntech says if noisy bearings then replace the pump stat. Death or injury may reult (or words to that effect). It's not a bearing noise though.
Either I'm the only one with this problem, or I'm the only one to notice it.
