Brake fluid question... Porsche vs. Audi?
I need to do a brake fluid flush and have used both Ate TYP 200 and Ate Blue in the past on my Boxster. If I can find a local supplier I'll probably use the 200 in my C4S. The local Porsche dealer wants $50 per liter for Porsche fluid and about half that ($13 for 16.9 ounces) for Audi branded fluid. If I can't find Ate locally any reason to not use the Audi stuff? I don't have any real plans on tracking the car but may do so once to get more familiar with it in a relatively safe environment.
Parts Specialist
IMO if you are not tracking the car Castro GT LMA cant be beat and @ about $10/qt you can fush the entire system with a great fluid for $20
I used it in my 996 and I have it in my 86' as well
Im using Motul. Its a bit pricey $25 if I remeber... but if you plan on tracking your car at all you wont have to worry about boiling your fluid. In my area it wasnt easy to find until i tried a motorcycle dealer nearby. They stocked plenty.
I use ATE TYP200 or Motul RBF600 on the C4S
I think I'll check a local source for the Castrol GT LMA and if it's not available I'll probably order a case of the Ate TYP 200 for about $14/liter shipped as I've got a couple of cars to do and it won't go bad.
bTW, ATE Superblue is just TYP 200 with blue dye. I stopped using ATE Superblue because it stains the lining and it's eventually harder to change with newer fluid later on. Maybe it's just an annoyance to me.
I wound up buying 4 quarts of Castrol GT LMA @ $8.99/Qt. at the local Pep Boys so I should be all set. I'll fire up the Motive power bleeder when I get back from vacation during a mini work-on-cars day at my place. I'll likely do a full flush on the C4S, my Boxster S and a friends Boxster.
a tip: Don't fill the power bleeder with fluid at all. Just fill the reservoir and use the powerbleeder to pressurize the system. It's less messy.
Just keep an eye on the brake fluid level in the reservoir. Typically, I can flush the system by having to 'fill' the reservoir twice overall, with the refill taking place per two wheels.
