Looking for Turbo Twist II for 01 NB
I am currently on the hunt for a set of the updated Turbo Twists for a narrow body car.
The fronts are not too difficult to find, but the rears are!
I would prefer to find the ones with a 47mm offset, but I guess I could use the 65mm offset ones with a 15mm spacer.
47mm part number is 996.362.140.02 (and 996.362.140.01 also I believe)
65mm part number is 996.362.140.04
If anybody has a source I'd be grateful - I know Suncoast has them for $800+ each, I guess I should say a source that has them for quite a bit less than that.
This is officially my first post, but I have been lurking for a while now and have learned so much from the forum it is unreal. On my list is to become a paying member and to post follow-ups thanking those who 'helped' me swap out my 01 shift console for the 997 shift console, get my lighter socket out for the swap to a US one, find those wheel part numbers listed above, point me in the direction of Mobilube PTX (from the Swepco 210 and impossibly hard cold shifting I had), how to get my cluster apart for a new bulb illuminating the oil pressure gauge, confirm my battery was a correct aftermarket battery, helped me figure out that I wanted to put the LN IMS bearing in (done), and on and on and on.....
Once I get the car on wheels that look good I'll get some photos on ASAP, as it seems newbies get crushed around here without pics...
Thanks in advance,
Hugh
Thanks in advance,
Hugh
