996 Forum 1999-2005
Took plunge and removed engine!
Old 05-17-2010, 04:12 PM
  #46
ivangene
Parts Specialist
ivangene's Avatar
WTG Jim!
Old 05-17-2010, 04:35 PM
  #47
Eharrison
Eharrison's Avatar
Sweet!
Old 05-17-2010, 05:00 PM
  #48
15psi
15psi's Avatar
Originally Posted by Shark Attack
WOW.. fantastic. Can you get more pix of the worn cam chain pad after you took it off and got it cleaned up.. How many miles?
Here is a close up pic of the top pad from the 1-3 bank. This was the worst pad. As you can see the wear was bad enough that 'rails' of the chain had caused deep ruts and the links of the chain were now coming incontact with the pads and causing deep pitting. The bottom pad had much less wear. ( I saw similar wear pattern on my 968 when I replaced them @ 100k)
The 4-6 pad top pad was not as worn and I'll post a pic tonight.
Replacing these eliminated the chain noise I was having on start up. The engine is quieter at idle. I had a little lifter noise (minor) and that appears to
be basically gone also.
The car has 101k. (But is feels and looks like 20k)
Old 05-17-2010, 05:24 PM
  #49
theporscheguy
theporscheguy's Avatar
Jim,
Fantastic job on the entire project. Bring your car to breakfast next Saturday and show it off.
Old 05-17-2010, 05:44 PM
  #50
Eharrison
Eharrison's Avatar
Originally Posted by theporscheguy
Jim,
For fun throw one of the old chain tensioner pads and a spilt cup of apple juice underneath the engine when you park. It'll give people something to talk about.
Old 06-21-2010, 01:10 PM
  #51
Brucechas
Brucechas's Avatar
Great job! Thanks for the valuable info.
Old 07-06-2010, 08:28 PM
  #52
johonole
johonole's Avatar
what jack did you use to pull the engine? I am in the middle of this.
thanks- john
Old 07-06-2010, 10:39 PM
  #53
Gaspasser19
Gaspasser19's Avatar
Very nice! Bookmarked for future reference.
Old 07-07-2010, 05:18 PM
  #54
Chaos
Chaos's Avatar
You are a brave **** with great friends. Getting it back is where I always run into problems !
Old 07-07-2010, 05:30 PM
  #55
15psi
15psi's Avatar
Thanks! Yeah that's when they all left
Putting it back together is more fun when I label everything, take pics and bag small parts.
I need to update this thread with final pics and the 'things I learned" plus a list of parts with #'s.
The good news is that is has been over a month, car runs better than even! And I sleep great knowing it has a new IMS and other parts. And I saved a ton of money!
Quick Reply: Took plunge and removed engine!
