Recommended fluid for 996 6-speed gearbox?
05-09-2010 | 01:15 PM
Quote:
Originally Posted by
LVDell
Two words boys......BREAKER BAR!
Not a 'topless' bar?
05-09-2010 | 02:50 PM
Parts SpecialistRennlist Member
two words....
NO LIFT !!
its easy with the right leverage position, but on your back on the floor... its hard to gain leverage even with a breaker bar
05-10-2010 | 01:17 AM
If it was left handed threads, breaker bar equals broken bolt. Gotta be careful boys.
05-10-2010 | 11:48 AM
LVDell
Delvac. I use it in my Turbo, GT3, and Spec Boxster. I'd recco it if you track the acr. If you don't see the track, then the Shell Transaxle.
LV, What are the benefits to the Devlac for track use?
05-10-2010 | 11:56 AM
goliver
HA - broken bolt?
try stripped tranny case !!! $$$$$$$$$$$$$$$$$$$
thats why I stopped... BTW its "normal threads" just CAN be tight as h&ll !!
05-10-2010 | 12:21 PM
Why in the world would they have reverse threads???
Eharrison
LINK
05-10-2010 | 03:59 PM
LVDell
Thanks.
05-10-2010 | 04:30 PM
LVDell
I didnt say they would.... but that bastard was really on there and had me "wondering" WTF was all.... I stoped and researched before going any further
05-10-2010 | 04:35 PM
ivangene
05-10-2010 | 04:36 PM
sorry I quoted your wrong post - I was refering to the the "why would they have left handed threads" question
05-10-2010 | 04:38 PM
Ah, that makes more sense
I ran down to Lowe's and picked up a black iron 2" diameter 3' pipe. Slide it over my ratchet and SNAP!!!! it loosens that sucker up with a sound that will make you think the case just split open
05-10-2010 | 04:41 PM
yea, a little scary the first time.
changing the oil on the 3.2 the drain plug spec is ~55 ft/lbs - I can assure you I stopped well short of that too - there is no way it needs to be that tight!
05-25-2010 | 01:50 AM
LVDell
Just received my gallon of this stuff today! Along with a pair of running shoes. (Lots of go fast stuff!)
05-25-2010 | 04:44 AM
LVDell
Oh dear Lord, get some side skirts on there to balance that out!
I'm sorry but I so disagree. Why mess with perfection, the lines on the stock 996 are absolutely beautiful.
