Boner Move - need to open trunk with no battery
Mr. Safety here disconnected battery to work inside the doors and then closed trunk before reconnecting battery! How do i get it open. Jumping wont work since battery is disconnected! HELP
There is a place inside the car to hook up a charger. Its in the fusebox by your clutch pedal. Its the red thing, you pull it out and connect a charger to it, which will give power to the car. Hook the ground cable to the door latch on the inside of the door jamb.
thanks for the lightening fast responses. Had tried jumping to the fusebox and it didn't work. Thought it was because the battery was actually missing rather than dead. But after searching some more I tried again and it worked. Just had a bad connection with the jumpers the first time. Thanks again.
