To use spacer or not to use spacers ? carrera III vs 5 spoke wheels ?
I know the topic of wheels is all over the forum, but I can't decide between two set of wheels for my 2003 narrow body C2.
I found at similar price:
- a set of 18" 5 spoke wheels OEM (1 wheel shown)
front: 8x18 ET 50
back 8x10 ET 65
- a set of 18" Carrera III wheels OEM (set of 4 wheels shown)
front: 8x18 ET 57 (spacer needed)
back: 8x10 ET 58
As you may know the Carrera III wheels were made for the 997 so they will require space in the front. and considering I already had some problem with my shaky steering wheel, I wonder if the spacer can be a problem or if I am worrying too much ?
front: 8x18 ET 50
back 8x10 ET 65
back: 8x10 ET 58
I have sets of both of those wheels. Presently, I am not running spacers on the 997 wheels and all seems to be well. I use the Carrera III's with Sumitomo HTZRIII for summer driving and autocross.
Granted, I'm a novice and I probably couldn't tell anyway.
any idea how much spacer will cost me or where to buy them online ?
also may be help about which one to choose...arghh there are a bunch of different one all look same to me![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
http://www.hrsprings.com/products/trak/
Parts Specialist
spacers range ini price from $300/axle to free ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I picked up 15mm H&R's for about $50 IIRC then found bolts on ebay for $10 !!! the seller didnt know whatthey were and had him measure them - what a deal ! - got free 7mm spacers and the bolts ran me about $20 (again on ebay) - took about 5 months to get it all together - if you budget about $200 you should be able to pick them up quicker
I would look at FVD Brombacher. They are located in Florida and product quality is top notch. H&R 7MM spacers, for example, are produced to fit many different makes. FVD only makes them for Porsche. I just ordered a set but had to wait a week for them as they are filling backorders from Germany. They can probably ship them from stock now.
I like the Carrera III's better, IMO.
I have 19 X 8 et 57 Carrera Classics up front and they were fine w/o spacers, but once I installed 13mm billet hubcentric spacers, the car is more stable at higher speed and it does give the wheel a slightly better look up front. the rears are 19 X 11 et 67 and look fine, but I'm debating some rear spacers for looks; I wonder if it'll help handling?
I didn't have any vibrations w/ or w/o spacers. I have the stock suspension and stock ride height.
I got my 13mm set and 10 longer chrome lugs from ezaccessory on ebay ( no affiliation) for $100.
I run the Carrera III's on my 996 as well. The fronts would be happiest with spacers, but they're not required. I did have to reduce the width on the front tire slightly to prevent any rubbing.
-Shawn
-Shawn
CHSU74, I assume you got those :
http://www.fvd.de/us/en/Porsche-0/99...cl.-Bolts.html
very decent price indeed.
BTW, I hope it is ok to post links to those stores ? I think there is something against posting to non spore stores ? I just figured it would help everybody.
2000996MIA do you have a picture with the 13mm spacers ? because I was thinking to get the 7mm to get back to stock, but now that I think about it, may be adding 5mm of bling might look good as well
Oh.... and I guess we found the forum worry wart.
-Manil
