Excellence Key fob article
$3.00 switch fix,the stealers are going to be bummed !
That is only the internal switches on the PCB if your fob light does not light. Like the one about checking the board for cracks in traces or solder joints and resoldering them. Still it is advancing the data base.
Tim's legs must be asleep by now ! Ring around the Toucan !
It tells how to replace the electrical switches(3) on the circuit board for $3.00 So simple a caveman could do it which means I will need help !
