Why is my car howling at me...
My car makes a howling noise from the front end coming from the gas cap area. At first i thought it was the fuel pump, so i replaced it and the howling continues...
I noticed that the howling only occurs when i barely step on the gas pedal, then as soon as i left off it disappears. The noise also goes away after i step on the gas pedal beyond the "barely step-on" point.
Note: the A/C is never on when this occurs.
Is there some sort of pressurization system in the gas tank? what are all the components forward of the battery besides the fuel pump and radiators?
Thanks. Any diagrams of the fuel system or vent system would be great as well
Here's an old post (circa 2002) from RobynC at Babblers that, I think, covers what you are referring to.
As noted in the response, I ran into the same problem on my 2000 Boxster S. The best I could describe it was the "Coke bottle" sound. Was very sensitive to throttle position. It would happen for me when I was just lightly cruising along and any additional throttle would make it go away. The dealer changed the valve and the problem disappeared.
Problem #1. Had this sound...best described as "when you blow into the top of a coke bottle"...coming from the front end...right. Happened at low speeds, hard to duplicate and only occurred with I was turning the wheel.
Found out this was the venting tube for the gas tank. Makes this sound when it opens. Tom, Rick mentioned you had this problem sometime ago. No TSB on it yet, Porsche is aware of it...I am going to let it go for now.
I don't remember off the top of my head. I'd either have to pull out the old work order to see what was replaced or take a look at the PET diagram. I can do the former when I get home unless someone else comes up with the answer before then.
Is it only during the full moon or does it happen with the new moon also? If there are other 996 around do they start answering? Did you take your meds today?
+1 for the tank vent.
Had something similar on a 72 with 1/2 of the evap stuff removed. It was more of a high pitched whistle on that car.
Could be the way the gas noozle flap seals so good. I've tried pouring injector cleaner additive in and its a pain having to hold the flap open to get the stuff into the tank. What I'm thinking is with the gas being drawn out of the tank air has to enter and going past a good seal on that flap it might be acting like a reed in a horn section of a band. Maybe a slight roughing up of the flaps rim would solve it. I figure a red hot poker through it is out of the question
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
http://www.pcars.com/porsche_parts/s.../p_136152.html
