Chopping stock springs
#32
You'd also lose that nice ride you got with the new shocks. When the car is lowered this way, it will eat up some of the available shock travel. That first bit of travel in a gas shock is the most compliant. Because gas has a natural rising spring rate, it gets firmer as it's compressed.
So, basically, in addition to the problems cited above, you'll lose the benefit that you started out wanting in the first place.
My vote is with those who say that shocks and springs should be matched. In all likelihood, a proper setup will give you a better ride than what you're contemplating anyway.
#33
yep, only on the Porsche forum do you hear them scream "OMG YOU CANNOT DO IT" in the meanwhile the real world moves along. The only real problem is the trial and error of cutting small amounts of coil and the labor of reinstallation to get the proper height you want. I'd recommend 1/8 of a coil turn or less per initial cut.
If you can document the drop per coil cut it would be super useful information to the forums.
#34
Since the spring compresses cutting a half inch off will end up being more than a 1/2" drop. This is besides being the wrong thing to do with a 911 that has tight enough tolerences already.
#35
Ironman 140.6
E-bay is littered with ads for Eibach, H&R, and other 996 springs for under $300 bones. This would be a much better way to go for hardly any money IMHO.
http://cgi.ebay.com/ebaymotors/EIBAC...Q5fAccessories
#36
Ahhh, you people are all **** - how low is too low? (Your too low when you start forest fires??)
http://www.youtube.com/watch?v=MzTMo...eature=related
Then there is the questionable concept of less (no shock oil?) is more...
http://www.youtube.com/watch?v=C8Kw5jiwhv4
#37
Another good example of this is adjustable anti-sway bars on our cars. I'm thinking of the 3 hole adjustable type. The bar is just a torsion spring really. Mounting it so the overall length is the longest yields the softest ride, conversly the shortest length the firmest. The diameter is constant, the difference in lengths makes the difference in resistance.
Use the same spring steel rod of the same diameter, one is 6' long, one is 5' long. Roll both lengths into coils 3" in diameter. The shorter coil will be significantly stiffer than the longer.
#38
The OP mentioned that he saw Chip Foose cutting springs on Overhaulin. Most likely the car was late 60s to early 70s muscle that did not have a very advanced suspension system. Hell, it most likely had leaf springs in the back.
#39
How do you cut these (especially the rears) and make them work as intended?
I do agree it is much easier to just buy what you want for springs these days, but if you are more adventurous it sure looks doable to me.
#40
the problem you will prob have is, the ends of the spring are designed as suck to sit and rest for a safe fit/ride. I would think that you would have to bend and chop $20 of the spring to get it close to right.
The openings a the top and bottom of the spring need to be a certain width to fit properly. I don't think this would be safe to do on a dd. If it's going on a track, i wouldn't trust modified springs.
#42
Don't know the phisics of why other than the linked posts which seem logical enough. I can tell you from real world experience of having lowered many Silverado and other trucks from the 80s, 90s to current ones, cutting springs makes em stiffer for sure. The real trick is matching shock valve rate with spring rate. Without the shock/spirng dynos (i think they are called) to measure it is guess work for sure.
Not a biggie for sure if you miss the best setup, but would be hard to get the same results that the Porsche engineers get with all the testing they do. For fifty bucks why not take Ivangenes springs giver a go and post up the reults. At the end of the day it is just a car. Your car. Do what you want. BTW, you don't have to heat the bejeezus out of the springs to cut em.
#45
I toyed with the idea of chopping springs. It's old school.
Another old school trick was to heat them up and collapse them to the length you wanted. They may lose tensil (sp) strength and become brittle and break. (I heard of someone welding on the little step on a Cessna 172 spring landing gear that eventually broke, OMG)
But, old school again, you can heat them up with an electric welder compress them to the height you want. If you do do it, let us know.
(or you can buy some used H&R's for about $200 and do it the "right" way)
