996 Forum 1999-2005
Slotted brake rotors for non-widebody cars?
Old 04-03-2010, 06:58 PM
LVDell
LVDell's Avatar
Originally Posted by garrett376
I don't know the answer to that, but after those events I listed, the pads are at 50-60% and the stock rotors have no cracks and little wear - car ran at 3400lbs for cal speedway, 3250 at Buttonwillow, and 3200 at Willow Springs on toyo RA1's/NittoNT01's. I never lost brakes even after standing on them frequently - cal speedway has a 130mph to 40mph entry to turn 3! It brakes with about the same feel as my 3200lb 964 race car with Pagid Yellows, but not near as much bite the 964 with PFC97's (but the PFC's cook the brake system too much even with BIG calipers on the 964 and crack the front and rear rotors after 1 event).
Brake temp paint would do the trick
Old 04-03-2010, 10:05 PM
MagnusB
MagnusB's Avatar
LVDell, I have installed the GT2 brake ducts up front to help with the cooling and use Motul RBF600.
I have Zimmerman standard rotors and Pagid Yellow pads.
Those rotors have worn down FAST! Almost one set of rotors for one set of pads.
Old 04-03-2010, 10:13 PM
MagnusB
MagnusB's Avatar
Originally Posted by mglobe
DBA makes slotted rotors for the front. They are available at a reasonable price from TireRack. I haven't found slotted rears, so I use DBA on the front, and stock rotors on the rear. The rears don't seem to be as susceptible to cracking. This is on my race car, where I use PFC97 pads.
Did you buy the 4000 series DBA rotors then? Looks worth a try.
Old 04-03-2010, 10:40 PM
mglobe
The Penguin King
mglobe's Avatar
Yup. They are crazing a bit, but holding up well after nearly a year. Of course I run at TWS mostly, and it's a track that's easy on the brakes.
Old 04-11-2010, 07:27 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
GiroDisc. 330mm vs. 317mm and a hell of a lot less problems -
Old 03-12-2012, 03:21 PM
CAHRERA
CAHRERA's Avatar
Partsheaven now has Solid Slotted Non-Drilled Rotors front and rear for 996 c2 C4S and Turbo, Boxster S, Cayman S, 800-767-7250 ask for Al, Jeff or Spencer
Old 03-16-2012, 06:38 PM
TrackDays247.com
Former Vendor
We have the 340mm replacments IN - easy install (no kidding) MUCH higher heat capacity...and lighter. MUCH longer lasting also -
Old 03-16-2012, 06:39 PM
TrackDays247.com
Former Vendor
Slotted, no stinkin' holes
Old 03-16-2012, 07:19 PM
SWK6Cup
SWK6Cup's Avatar
Anyone tried Chris at LC Motorsports? I believe he has slotted rotors for sale and would be happy to help you figure it all out.
Old 03-30-2012, 12:56 AM
MagnusB
MagnusB's Avatar
A followup on the DBA 4000 series rotors, I would not buy them ever again.
Not for track use, perhaps for street.
Wore to pieces in no time at all.
Old 03-30-2012, 10:11 AM
mjdavis
mjdavis's Avatar
I used Girodisc during last year's track season. Rotors still look new. I've been impressed with the performance over stock, no fade at all, very good pedal feel, very strong stops, although I'm certainly not the fastest guy out there. I will say that Girodisc plus RS19s is a pretty noisy combination.
Old 03-30-2012, 11:23 AM
bella1
bella1's Avatar
Default Slotted Rotors
I bought fronts and rears from Chris in January. Installed and ran at Road Atlanta last weekend. They are holding up just fine after three days. He ordered them from Sebro and, according to Chris, Sebro also manufactures the stock cross drilled rotors for Porsche. At $160 per corner, they are quite reasonable. Contact info for him is 315-409-3500 chris@merlinmfgusa.com and www.merlinmfgusa.com
Old 03-30-2012, 11:10 PM
911FM
911FM's Avatar
Was also tired of cracks on drilled after a few days of track. Bought front slotted from LC. They were mounted last week. Will try on the track next week.
FM
Old 03-31-2012, 08:21 PM
LC MotorSports
Former Vendor
LC MotorSports's Avatar
Alex/FM, thanks for your support and kind words. The slotted fronts and rears are a great alternative to the Alcon's (great option as well) we carry for the cost minded users.
Feel free to call or email with any questions.
Chris
Old 04-01-2012, 01:54 AM
jrgordonsenior
jrgordonsenior's Avatar
What's wrong with a few cracks? I change my front OEM rotors maybe once a year and I race 2 series, total of 32 races per year. I have 3" ducting from the grill thru to the back of the rotors and I'm sure that's responsible for the longevity. And my weight (2600) is also contributory but still cracking is normal.
I do however have a set of Stoptech calipers and rotors for the front end of a 996 if anyone's interested.....
Quick Reply: Slotted brake rotors for non-widebody cars?
