Dension install in 996 Turbo with CDR23 (complete step-by-step with pics)
Did anyone else notice the ring ? Just sayin!
Gregg, was that it? The irony?
However, for those that are curious. The ring has the inscriptions represented in 1 Corinthians 13.....Faith, Hope, Love.
I've got an 03 turbo and today tried to fit my mObridge system but stopped when I found that the MOST connectors were different. My research has led me here to find out that I too have the Yazaki connectors where as the mObridge has the Tyco. I don't think that the adapter lead will work for me as the MOST plug is different for the mObridge, so I am trying to work something else out with the mObridge agent.
Sorry, never heard of the mObridge so I can't be much help. Hopefully they have something similar to what Dension has allowing you to replace the Tyco with Yazaki.
How did you come about choosing the mObridge? From what I understand, the Dension is the gold standard in the industry.
Success!
It worked like a charm!
I fitted mine in the space under the CDR 23 and rolled the excess cable up and put it behind the storage trays in the cockpit rather than the front luggage compartment.
I ran a tap from the cigarette lighter for power which seems to be working fine
Thanks again Dell
Thanks again Dell
Hi, I saw in the dension installation guide said that will need to activate the CD change in system to install the module. Did you activate the CD change before you install it? My car is 03 Cayenne S with CDR23 and MOST bose system but no CD changer. Thanks!
