Freaking coolant leak
Ok I have a leak, the leak is DEFINATLY coming from the connection at the pump. Where the hose attaches that goes up to the over flow bottle.
I have replaced this hose, I cleaned up the pump outlet really well and today, it started leaking again.... Ideas?
Thanks!
Thanks!
You sure its from the hose and not a hairline crack in coolant reservior???
Parts Specialist
I think it will cure itself once your water hits 206 degrees......
OH wait - yours wont ever hit that high
I thought I was leaking water the other day, but it was just raining out
I am mean, sorry Kyle - damn water leaks suck
Does the pump have any casting flash\mold lines on the nipple? New full contact clamp? Oetiker or other full contact band clamp so you can crank it down without cutting the hose?
