CLEANING ENG/TRAN
CLEANING ENG/TRAN
GooGone
BEFORE GOOGONE
NEW PICS AFTER GOOGONE. Clean off with water. Also cleaned off rubber hoses. Steel brush drill bit and steel wool was used on exhaust pipes.
2002 Porsche 996 C2: IMS upgrade from Chicagoland featuring LN Engineering.
BEFORE GOOGONE
Rocky Mountain High
Did you do the top side of the engine/engine bay too?
It’s really not that bad to do since the underneath components are covered with a beeswax type substance and then covered with dirt and dust. The GooGone removes the beeswax which could be easily rinsed of with a water hose. This would have to be repeated if you don’t want to scrub with soap and water.
Chris - that looks great! I'm going to do that now that it is getting nicer outside. Looks like a good Saturday project. I've been working on the exhaust pipes for a while now but the rest of the underside should not be neglected.
Excellent results, but I didn't find the Before pics bad to start with
Was this done on a cold or warm engine??
Looks really nice!!
