EVOM V-flow fitment issue on 996
I recall some people having issues with the fitment of this intake. Was this ever resolved?
Okay, I attempted the install this morning. When installed, mounting screw for the L-bracket contacted the sheet metal surrounding the hinge. With the L-bracket in place the back of the unit contacted the PS pulley.
If I removed the L-bracket I bought myself 1/8" clearance but the unit is unsecured. I'm not comfortable with that tight of a clearance and certainly not with the intake unsecured.
I'm going to email EVO and see if there are any easy fixes. I thought I'd just be able to switch out the screw on the bracket but even then it's a little too close for comfort. I'm not sure what I'm going to do at this point.
-Shawn
-Shawn
So you have it shifted to the passenger side to avoid contact with the L-bracket. I notice you don't have it secured with the bracket. Interesting. Thanks for the pictures. Here's what it looks like in mine.
looks like fly996 doesn't have the EVOM bracket for the air pump installed- installing this will move pump more to left allowing CAI to move to left and not hit air pump.
I've had the EVOM on my 02 996 for few yrs with L clamp fitting perfect in stock hole. Not sure what the issue is with yours-
Could you post a pic?
EVOMS part that came with the intake.
I just took some measurements of airflow with the unit. I'll post those in a new discussion thread. The tolerance between the pulley and the intake is DAMN tight. There's no way I can use the bracket. I was honestly hoping to see no difference in airflow so I could have a good excuse to take it out and sell it, but there were certainly gains from ~4000 rpm and up.
I have it as well and it fit fine in my '00 996 Cab. I used the new airp pump bracket that came with the kit...although it wasn't mentioned in any of the directions that I had to go the web site and look up (instead of being included with the kit) all this for the low low price of $695. I was not impressed.
However.... its the best sounding intake there is.... And I wouldnt necessarily call it a "cold" intake either. I think Porsche has the best "cold" intake design, but sounds a bit dull.
Exactly - you need the new bracket for the secondairy air pump. You can see my install thread here:
https://rennlist.com/forums/996-foru...u-upgrade.html
![](http://is.rely.net/2-31-41248-l-qDVcDv0YZCGb4hqmvUrBNg.jpg)
- Anthony
- Anthony
