996 Forum 1999-2005
headlight cleaner
Old Feb 26, 2010 | 08:43 PM
emdog's Avatar
emdog
Default headlight cleaner
I've heard some people recommend mcguires plastic cleaner, are there any other suggestions or methods that people use on here to make their headlights super clear?
Old Feb 27, 2010 | 08:46 PM
GAGMAN's Avatar
GAGMAN
I've had good luck with Turtle Wax rubbing compound and polish. Depending on how clouded or scratched your lenses are to start with, start with the more aggressive paste and work back to the final finish, just like you would on your paint.
Good Luck!
Old Feb 27, 2010 | 09:12 PM
Goldenwarrior1's Avatar
Goldenwarrior1
My 02 C4S lights are clear but I have used 2000-3000 grit wet sand followed by a 3M plastic polish with exceptional results on several cars including a 2005 M3.
Old Feb 27, 2010 | 09:14 PM
drh's Avatar
drh
Originally Posted by Goldenwarrior1
My 02 C4S lights are clear but I have used 2000-3000 grit wet sand followed by a 3M plactic polish with exceptional results on several cars including a 2005 M3.
We did the same thing on my daughter's ML320. Her headlights were all yellowed out and now they look like new.
Old Feb 27, 2010 | 10:47 PM
gota911's Avatar
gota911
Newbies Hospitality Director
I used this on my Jaguar S-Type headlights lenses when they became cloudy and had yellowed. It worked extremely well. I loaned the bottle to a friend who had a 6-year old daily driver (Nissan) with the same problem. He was very pleased with the results, too.
http://www.cargobluemagic.com/
Old Feb 28, 2010 | 10:24 AM
xel996's Avatar
xel996
I tried meguirs with 5 coats and didnt see any difference. I then tried mothers plastic polish and it worked better for me. Dry sand the lens first using 400 then wet sand with 1000,1500,2500 then the plastic polish products mentioned. Dont use rotary tool for sanding or you might end up melting the lens.
