LOKASIL beyond 50,000 miles.
Has anyone seen anything about Lokasil bores becoming OVAL on the 3.6 ? This can't be right.
"The cylinder walls in the 3.2 were modified over the 2.7 (which was bored out from the 2.5) to maintain a decent thickness, but the 3.4 and 3.6 are simply bored out further from the 3.2 to obtain the right capacity. This results in a reduced wall thickness and a thinner LOKASIL liner – a cylinder lining system fitted to all Porsche water cooled engines (except the GT3 unit which uses NIKASIL). The metal matrix of the LOKASIL is not perfect and over time they can fracture, and the bores almost inevitably become oval beyond 50,000 miles." Total 911 issue 41.
![](https://lh3.ggpht.com/_OB3UxaVI4n0/S3rM3QrnucI/AAAAAAAACug/DxUB2eawDbs/s800/localizedborecontent.jpg)
Close-up of the localized Lokasil liner in the M96/M97 block; later revised 3.6 block shown with reinforced webbing.
The later 3.4 blocks (like on the Caymans), do not have these improvements. We see lots of these blocks and it's interesting to see the differences and how Porsche maintains product differentiation to maintain the superiority of the 911.
The key to keeping them round is to keep them cool. We joke that the coolant temp light is the "rebuild" light.
When you guys speak of the cylinders becoming out of round, by how much? What is the greatest amount that you have seen and consider it still runable?
Also, I'm assuming the out of round is distortion rather than wear, is that correct? Are the cylinders originally finished with torque plates bolted on to simulate distortion from the crank support girdle and heads? Or are they finished in a relaxed state? Could the measured out of round be dimished or eliminated when the motor is fully assembled and at operating temperature?
Sorry for all the questions, I just find this motor rather facinating and have since I first read about it in Road and Track in about '96 or so just prior to the first production vehicles being released. The main reasons I bought a Boxster and later a Carrera. TIA
As there aren't any published specs for the lokasil bore that I am aware of, I'd say anything over .002" ovality is too much. Most of the blocks we get here for re-working have at least that much and upwards of .005-.006".
The bores are finished straight and that's how we do them. We did tests years ago and found that trying to use torque plates and simulate actual engine parameters was a crap shoot. You get the best results with a bore as round as possible within .0005".
Yes, the castings for the blocks are the same between the 3.2, 3.4, and 3.6. The 3.4 and 3.6 share the same bore size, just the 3.6 has a larger stroke. When they came out with the 3.8, they updated the castings to provide more substance to them for the larger bore size, which then the 3.6 block by default received those upgrades. From best I can tell, the 3.4 engines in the Boxster and Cayman did not receive those updates, retaining the design of the earlier blocks with exception of added windage notches where specified.
I have a 2008 Cayman S and would like to increase the displacement and making it a "bulletproof" motor, but from the sounds of it I am better off scrapping the idea completely. What are the choices here if one does not want a 911 but wants a Cayman?
The big bore kits use special sleeves that interlock at the top and create a nearly closed deck which helps strengthen the engine.
As for bullet proof aftermarket high performance pistons, rods, crank, and other hardware can go a long way to making the engine more robust.
Check out www.flat6innovations.com for info on big bore kits.
Uh, check that. I just visited the site and only 2.5l and 2.7l engines are supported. You can give the shop a call though and see if it has anything planned for the 987 3.4l engine.
Overseas, there is Autofarm and Hartech both located in the UK.
Another path is to remove the stock 3.4l engine and install a 3.6l or even a 3.8l engine from a 997 car, probably one from which the engine has been salvaged.
One might even buy one of these engines but I bet the cost would be prohibitive.
But as the saying goes: Speed costs money. How fast you wanna go?
Sincerely,
Macster.
Thanks for the great info gentlemen. This gives me some things to think about. I have been tossing around going from the 08 to an 09 for DFI but if I can build a very strong motor and keep the 08 I would prefer to do this.
I like the idea of getting a 3.6 or 3.8 from a 911 donor car and building on it.
Cheers
Cheers
Sincerely,
Macster.
And so yet another generation of Porsche owners secretly anticipates the day their motors wear out so they can justify a high performance rebuild.
It seems the 996 is a 911 after all.
