Rim/Tire question
MY 04 C4S has the turbo wheel in which the spoke is flush with outside rim and the little semi circles between the spokes ( see Dennis's picture). It is a 11" rim. It is also hollow in the back
Weathergirl
You guys should check out http://www.944racing.de/reload.php?u...elweights.html (sorry about the url--doesn't load right without the first part).
The first one Dennis C posted is a stock 996 17" wheel.
Between the two turbo wheels, the one Marc Gelefsky posted is the "Turbo I" 993/early 996 version, available in both narrow and wide offsets, but only up to 10" wide rears. The turbo twist Dennis posted is the "Turbo II" 996 version introduced in 2001, and is available in widths and offsets and solid and hollow spokes for both narrow and wide bodies, but only the wide bodies get the hollow 11" rears. The link above lists all the options and part numbers.
